Brakes
Old May 13, 2005 | 08:23 AM
mickeyderry's Avatar
mickeyderry
Cool Brakes
I have 95 PSD I have bleed the master and all the lines with the engine off the pedal gets hard. Once I start the engine the pedal get real soft and I tried it with the engine running no diff. Help<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old May 13, 2005 | 09:02 AM
gseeders's Avatar
gseeders
make sure your rear brakes are adjusted, start bleeding brakes furthest from the master cylinder. You can do this yourself,If you put a small amount of brake fluid in a coke bottle and attach a rubber hose to bleeder valve and surmerge the other end in the fluid in the coke bottle, pump brakes till air is out before moving to the next,keep close eye on brake fluid level as it can empty out quickly.
gseeders
Old May 13, 2005 | 09:56 AM
mickeyderry
did that I called ford told me to put it on ABS Computer then bleed it. do you know where the ABS box is.
Thanks
Old May 13, 2005 | 10:09 AM
gseeders's Avatar
gseeders
Thanks
Sorry but i don't, It should be easy to locate,all brake line that are controlled by the abs should go to it.
gseeders
Old May 17, 2005 | 06:33 AM
mickeyderry
Thanks guys it was my master Cylinder.
