Sponsored by: Real Truck
Power window problems
Old May 13, 2005 | 07:04 AM
360and444's Avatar
360and444
Recently the drivers window on my 99 F-350 started to slow down dramatically especially on the way up. Most of the time, it now needs help to get to the top and occasionally if I let it rise all the way to the top, it won't come back down for a while.
Has this happened to anyone else and if so was it the motor or track? How hard is it to remove the door panel? What is the procedure?
Thanks in advance for any and all help.
Travis
Old May 13, 2005 | 01:39 PM
Musicman250's Avatar
Musicman250
Door Panel Removal, see FAQ sticky at top forumn
Old May 13, 2005 | 03:36 PM
360and444's Avatar
360and444
Thanks. I found it.
Has this happened to anyone else? Does it sound like I need to replace the motor, switch, or regulator? How about just oiling the tracks? Any ideas?
Thanks in advance.
Travis
Old May 15, 2005 | 05:40 AM
wolfbike1500's Avatar
wolfbike1500
I had the same problem except my window would be real slow going down. This was sometimes embarrassing at toll booths. It turned out to be the motor. I had the dealership do it because I needed to bring it to them for diagnosis. They didn't screw me too bad really. 360 got me a new motor and an oil change.
99 F-350 Lariat V-10 4x4 CC LB SRW
