Tires
Old May 12, 2005 | 10:40 PM
TONINA's Avatar
TONINA
Tires
Y Have A 1995 V8 4x4
Y Have 4 10 Dif.
Y Have It Now With 33. Shouls Y Have To Change The Pinion And Gear???
What Happend If Y Put 35 With 4 10 Diffs????
Thanks A Lot And Sorry About My Poor English.
Old May 12, 2005 | 11:52 PM
MustangGT221's Avatar
MustangGT221
Where are you from? I'm interested to know.
Changing to 35s should be acceptable. If you want more power you could change to 4.56s but not necessary.
Old May 12, 2005 | 11:57 PM
TONINA's Avatar
TONINA
y have all std in my truck
and fuel milaage ??????
if y put 4.56 y will have better fuel millage
thanks a lot
Old May 13, 2005 | 07:17 AM
F-Liner's Avatar
F-Liner
No. If you install 4.56 gears, then you will have better power usage. If you keep the 410 gears, you may be a little slower taking off but you should see a little better on the highway. The problem with this theory is that the truck will push more air with bigger tires.
Old May 13, 2005 | 09:24 PM
DARK_HORSE's Avatar
DARK_HORSE
I have 33s with 410 gears and a 302. I wish I had 456 gears. It already has no low end power and I can't go faster than 70mph.
Old May 13, 2005 | 10:05 PM
moose94's Avatar
moose94
Well ya got to take one or the other. A 3.55 ratio will provide you with more top end speed. But a 4.56 ratio will give a better crawl ratio. Also depends what tire size you are running. A 4.10 rear with the t-case in low would work just fine.
And you don't get better gas milage in going from 4.10 to 4.56. Just not going to happen.
Old May 16, 2005 | 09:32 PM
TONINA's Avatar
TONINA
would you put 35 tires with 410???????
if y use 35 tires only for offroad y can break something with 4 10???
with 35 tires .
with 35 tires or with 33 can y break the power steering
when y put the 33 the power steering do a noise when y turn click click click
