Problem - backfiring under (moderate acceleration)
Old May 12, 2005 | 09:48 PM
denisontexas's Avatar
denisontexas
I have a 1956 Ford F100 with a 5.0 L Hi-Perf from Ford Racing (SVO aluminum heads, Weiand Intake, Edelbrock 750 CFM, shorty headers, MSD 6AL), etc..
It ran great from the time it was installed until I put the truck in the paint/body shop...it was in paint about 4 months...
Current Status:
Starts great
Idles (ok with no backfire that I can tell...it has an moderate-aggressive cam, so I'm not sure if it happens here...)
Hard Acceleration (good - no backfire)
Moderate Acceleration -
When I'm going about 5-20 mph and apply gas to either maintain the current speed or accelerate just a little, I get a pretty loud pop that you can feel(sounds like a carb backfire). It happens consistently (every time, about 4 or 5 times per minute).
If I accelerate hard up to 70-80 mph and completely let off the gas; it coasts down to zero perfectly ok without the popping/backfire.
Could this be vacuum or plug wires, etc...
Any suggestions ?
THanks
Mike@logic2.com
Old May 13, 2005 | 12:28 PM
Kemicalburns's Avatar
Kemicalburns
check the power valve, timing, vacum lines for leaks. how do the plugs look
