Dually Spare Question
Old May 12, 2005 | 01:35 PM
polar88's Avatar
polar88
I finally found a spare wheel at a junk yard for my 99' F350. The greasemonkey said that it was for the inner dual. Is there a difference in wheels between the inner and outer, how about the front? These Ford 16" are sure hard to find, Chevy dually all day long, but Ford is rare here in Las Vegas.
Old May 12, 2005 | 01:39 PM
Max1775's Avatar
Max1775
All six wheels are the same, unless you have aluminum rims. Then the back insiders could be steel. Hope it helps.
Max
Old May 12, 2005 | 01:41 PM
polar88's Avatar
polar88
My wheels are aluminum. How much does that change things? This extra wheel is for a spare only so looks don't matter much.
Old May 12, 2005 | 01:47 PM
Max1775's Avatar
Max1775
Spare should work. It is steel right?
Old May 15, 2005 | 09:46 PM
RedTaurus94's Avatar
RedTaurus94
Yep....with the pretty aluminum rims, the visible ones are aluminum, and the rear inners are steel. Pretty sure either rim will work as a spare as long as the bolt pattern is the same.........
Old May 16, 2005 | 11:34 PM
loadmax's Avatar
loadmax
The steel wheel will work on the front or back, watch out on the aluminum ones tho they should be marked front and rear. The reason for this is that they are only polished on one side so if the rears get put on the front and the fronts get put on the rear like mine came back from Walmart you will notice that they arent as shinny as they should be.
Old May 17, 2005 | 02:49 AM
vinman46's Avatar
vinman46
I needed to get a spare rim for my 2000 PSD dually and that`s when I found out that starting in `99 they switched to a 170mm bolt pattern.
Old May 17, 2005 | 12:38 PM
duallydawg's Avatar
duallydawg
Yep all the rims will work on any wheel. Bolt pattern is the only concern. The steel rims are thinner than the aluminum ones so I don't know if you can run two aluminum ones together unless the studs are long enough.
Old May 17, 2005 | 02:26 PM
Sam'sPDS's Avatar
Sam'sPDS
Mine are aluminum
I have 4 aluminum wheels for the out side. the inner wheel are steel. Which can be mounted either way. Also the aluminum wheel are marked for front and rear applications.
juanrodriguez
Jan 9, 2015 06:40 PM
Kri
New Member Introductions
Nov 23, 2013 03:40 PM
timb1776
Jun 21, 2012 08:35 PM
snb13
Jul 25, 2004 09:40 PM
