88 302 efi compression
Old May 12, 2005 | 11:00 AM
parshdude's Avatar
parshdude
What should the compression be on an '88 302 efi, I am headed to the shop to check the compression, my symptums match some others found in the forum and this was recomended, but I would like to know what I should be looking for.
Old May 12, 2005 | 11:13 AM
EPNCSU2006's Avatar
EPNCSU2006
The most important thing to look for is evenness across all of the cylinders. I don't know an actual number that the compression should be, but I would think up around 150 or so would be pretty good.
Old May 12, 2005 | 12:12 PM
VectorFord's Avatar
VectorFord
I don't know what kind of numbers you're looking for, but the chilton manual says stock compression in that year should be 9:1.
Old May 14, 2005 | 08:44 AM
rustyoldford's Avatar
rustyoldford
My 89 302 checked 80- 150 last month. Certainly not even but was running ok, but won't start now.
No popping spitting or other signs of being interested. Sprayed some ether in it, got mild sputtering, will be checking for gas flow somehow this morning. How does one disable the advance when hooking up a timing light, I miss my vacumm advance distributor
Old May 14, 2005 | 09:32 AM
robnrob10's Avatar
robnrob10
approx 9:1 cr and around 145-155 on tester.
to check timing, remove spout near dist. rectangle grey plug.
Old May 14, 2005 | 10:53 AM
rustyoldford
Needed bigger dose of ether to pop sputter, and almost start. No fuel pressure in rail though, can hear neither fuel pump running in fore or aft tank. Will attemp to find fuse labeled fuel pump. Didn't have crash but will look for crash switch also.
Actron code scanner won't read codes either.
Old May 14, 2005 | 12:02 PM
rustyoldford
Can't find a fuse, can't find crash switch. I know my 85 has a crash fuel pump shutoff switch on the floor hump passenger side, thought that was on everything now.
Maybe someone has color code for hot wire and Ill just crawl undet truck and add new pump hot lead
Old May 15, 2005 | 06:33 AM
rustyoldford
Found a corroded off lug on fuel pump relay, can't dig whats left of it out of the socket either, but I found it
GuitarJesus
May 5, 2016 07:28 PM
AKHunter93
Nov 25, 2015 07:41 PM
AKHunter93
Nov 21, 2015 04:20 PM
kh0432
Sep 11, 2015 03:48 PM
moose4130
13
Aug 24, 2003 06:42 AM
