Sponsored by: Kumho
Need help on wheel situation!
Old May 12, 2005 | 09:53 AM
Brian794x4's Avatar
Brian794x4
Alright, i got the wheel adapter situation figured out with the help of Cody, now i was going to put up my delema about wheels. I have a set of 15x38.5x16 Boggers sitting down at the tire shop, and i ordered a set of 16x10 Eagle alloy
"058" wheels. Like the simple yet nice look to em, so i thought i had it made.
Then i read Max tire size........32". WTF! Thats retarded. That is practically what comes on most full size trucks stock now. We're talking a 8 lug, descently wide wheel! I know they have a buffer to cover their own asses and all, but thats a pretty low bar. I KNOW dam well ive seen trucks with at least 35's on these wheels...so im kinda stumped. I got the shop to talk to eagle, and the one guy said that that is just a number for warentee porpouses so they cover their asses, but he didnt have alot to say about exceeding that. Help me out boys, i need your opinions. I have spent huge coin so far on this ol 79 150, with the D60, the SD rear diff, gears and lockers, lift and crap, and wanted to get a relatively inexpensive nice looking wheel, which this wheel is exactly that, but also dont want to do something if its inevidable that it'll crap out...help!
Sorry for it being so long
Brian
Old May 12, 2005 | 07:41 PM
Lou Braun's Avatar
Lou Braun
Most aftermarket rims will have a maximum tire size, a maximum inflation pressure and max load rating. Since you are spending quite a bit on the rims and tires, I'd get rims that match your new tire size and maximum sidewall inflation pressure at a minimum.
Big tires really stress front rims when you make a high speed turn (lots of leverage). Running under-rated rims on the street is not a good idea.
If cost is important, an option would be running aftermarket steel wheels. These usually have very high ratings and the price is right.
Lou Braun
Old May 12, 2005 | 08:37 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Listen up!!! DO NOT EXCEED THE WHEEL MANUFACTURER'S RATINGS!!! Been there, done that. Although it was unknowingly, I had exceeded WELD WHEEL INDUSTRIES ratings for their "StoneCrusher" style wheels. I was at the maximum for weight rating (3200lb. and I am at 3400/front) and also for tire size rating. The wheels were rated for 44 inch tires....I was running 49's on them.
To put it in a nutshell, while travelling in a straight line at 72 MPH, the LF wheel split right at the bead surface half way around the circumference. The LF corner of the truck dropped about 13 inches and across the 2-lane I went. They won't warranty the wheel, they don't make the wheel anymore, and no one in the country has any in stock.....I've got 3 useless wheels.
I've since ordered a set of Stockton steel wheels rated for 4000 lbs. and the 49 inch tires.....once they get here I'm mounting them and proceeding on my merry way down the interstate once again.
Cody
On a side note, one of my best friends is running Eagle 058's on his 1000 HP mud bogging truck. It weighs about 6300 lbs. and he's turning 39.5 Boggers on 16.5x12 Eagles. Hasn't had any problems in 4.5 years.
Old May 12, 2005 | 09:32 PM
Brian794x4's Avatar
Brian794x4
yeah cody, i heard your horror story. I was telling a buddy with a big superduty the story a while back. Thats a long *** way to fall down for sure. I knew there would be a max tire size rating, but i didnt think it would be the same size as most full size 3/4 tons come out with stock now days...seemed insane. Hmmmmmm, i do hear what your saying about your buddys truck too........god damit, they are a nice looking wheel for like 90 bucks a piece. Oh the drama
Brian
Old Jun 16, 2005 | 11:44 PM
SilverHighboy's Avatar
SilverHighboy
I just bougt a set of american racing Baja's 16x8 for my 76 250 highboy and they won't fit the front axle the brake caliper bolt hits the back of the rim! I seen you said something about an adaptor by chance is that what you used it for? by the way they have a 4.5" backspacing 0 offset.
