Possible Shift Problem
Old May 12, 2005 | 08:24 AM
smitty1956's Avatar
smitty1956
I just purchased this 71 F-250. Great truck and the body is straight and all and very little rust. It drives great, but on the highway, it seems to run higher RPM's. Seems like it should go one more gear into an overdrive mode or something. I think it is a C6. What is a possible solution or check to see. I haven't driven an older truck like this in a while and I hate to think of a new or rebuilt tranny at this point. How can I tell? If it is not hitting that last gear, how hard is it to go into and fix?
Rich
Old May 12, 2005 | 09:24 AM
4Cammer72's Avatar
4Cammer72
you should feel two shifts. if not then it could be linkage or tranny itself. if it does shift to third then its probably the gearing. the solution for gearing is to swap the gears for a set better suited for highway driving.
Old May 12, 2005 | 09:42 AM
smitty1956's Avatar
smitty1956
Well then perhaps it is okay! I do feel two shifts, it just seems higher to me.
thanks!
Rich
Old May 12, 2005 | 09:46 AM
Mike G's Avatar
Mike G
If you post up the trans and axle codes from the door plate, perhaps we can pinpoint where you need to go next. Also, I'm guessing it is running a 360?
--Mike
Old May 12, 2005 | 09:59 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
LOL...I know where he's coming from.....after driving my wife's GP with the 4 speed AOD...it runs down the HWY in 4th @ 2000rpm @70mph.....
I get in my 70 F250 with 3:73's and the C6..Its 2800rpm @ 65mph...lol...
Just had to jump in.....
Russ
Old May 12, 2005 | 10:41 AM
smitty1956's Avatar
smitty1956
Thnaks Mike thanks Russ,
I can get the codes tonight when I get home, 8:00 pacific time. Let you know then.
THANKS!
Rich
Old May 12, 2005 | 10:49 AM
4Cammer72's Avatar
4Cammer72
a taller tire will help some also but the speedo will be off then but that is a cheaper way to get a lower rpm on the road than a gear swap. just an idea.
Old May 12, 2005 | 12:22 PM
smitty1956's Avatar
smitty1956
Mike G here are the codes under the VIN number on the plate form the door of my truck.
VIN#....
131 B F250 A 4 G 38
07500 170 4100 71
Let me know what you think, is this a C4 or a C6?
Rich
Old May 12, 2005 | 12:24 PM
4Cammer72's Avatar
4Cammer72
it cant be a c4 with a big block
Old May 12, 2005 | 01:23 PM
oppy's Avatar
oppy
Based on your tag info, I think you probably have a C6 auto and an open Dana 60 with 3.73 gears. With this setup, you're going to rev pretty high at 70.
Old May 16, 2005 | 10:33 AM
Mike G's Avatar
Mike G
Sorry Rich but I'm not too keen on the codes for the "newer" trucks. I would have to agree that if you have a set of 3.73's out back, your highway rpm range is right on the money. A FE engine, be it 360 or 390 will not have a C4 bolted up out back but a C6, and with it appearing to have 170 HP at 4100 rpm, my vote is a 360. If you want less rpm's on the highway, you can always go to a lower numerical gear set, like a 3.07 or so.
--Mike
Old May 16, 2005 | 10:48 AM
smitty1956's Avatar
smitty1956
Mike, what does that entail? How do you go to lower gears? Open the tranny up and swap things?
Thanks!
Rich
Old May 16, 2005 | 11:52 AM
wyatts72's Avatar
wyatts72
i know what you mean russ when i get out of my 92 and in to my 72 i swear its about to blow 3000rpms @ 65mph. but when i get in to the edelbrock carb it still sets me back in the seat. think i need taller gears to but 1/4 mile speed is super been smoking mustang gts everytime they try me
Old May 16, 2005 | 08:19 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Mike G, he has a 250 Dana 60, 3.54 is the highest ratio available. Your speaking 100 with 9" rear for 3.07's. Taller tires like 9.50 x 16.5" will help. How loose is your convertor, not stall speed? Tire diameter? I have 12.00 16.5 rear, 3.54 with C-6, 410ci with a custom tight convertor, 2,460 rpm's at 60 mph. Only time it needs higher gear is on a "mission run" at 90-100 mph.
Carl...=o&o>....
Old May 17, 2005 | 09:52 AM
Mike G's Avatar
Mike G
Carl...=o&o>....
Carl's right on...
--Mike
