Rear window leaking
Old May 12, 2005 | 07:20 AM
jojo41's Avatar
jojo41
Rear window leaking
Hello! Now I found out that my factory installed rear window is letting water in on the inside lower corner on the passenger side, water constantly drops on the belt roll-up-assembly.
The rubber sealing looks good all around, no cracks to be seen, jut a lot of "green mud"....
As my truck carries a campertop,the rear window is impossible to clean properly regulary from the outside.
Is there anything special to be careful of, when pulling the window out? Any ideas for parts to be replaced before re-installing and a good adress which ships internationally to buy these parts at?
Thanks for your support
JoJo
1990 F150 std.Cab, short bed
