Sponsored by: Kumho
Add power steering
Old May 11, 2005 | 08:36 PM
hillview's Avatar
hillview
Question Add power steering
I want to add power steering to a 73 F100 with 3 spd manual. Is it possible? How big a project? Any help here would be appreciated.
Old May 12, 2005 | 01:45 PM
73Custom's Avatar
73Custom
Is this a 2wd or 4x4? For 2wd get these parts from a 2wd '73-79 F100-F350:
3 spd power steering column (shorter than manual steering column)
power steering box
p/s hoses, pump, brackets and pulleys for your peticular engine
Once you get the parts, it's a matter of swapping the power parts for the manual parts. The center steering column shaft will interchange between 3spd, 4spd and auto columns. So if you can't find a power 3spd column, just changing the center shaft would be an option. That's what I did with mine, used the original 4spd column but swapped in a shaft from a power steering auto trans column.
For 4x4, check the tech articles in the 'articles' link at top of page.
Marty
