steering noise?
Old May 11, 2005 | 06:22 PM
motox214's Avatar
motox214
Unhappy steering noise?
When I turn my steering wheel, it sounds like a horror movie when someone is coming through an old screaching door. or it sounds like a leaf spring pack gone bad when weight is put on it. What really stumps me is when I jack the right front of the car up and turn the wheel you cant hear the noise. So I am guessing, whatever it it is, it has to be weight bearing? Any suggestions? I know it is on the right side, and it will do it however long I want to keep turning the wheel back and forth. It seems like it just happened overnight.
2000 4x4 Ranger Thanks!
Old May 11, 2005 | 07:55 PM
Ken00's Avatar
Ken00
I would suspect a bad ball joint, why don't you have someone turn the wheel with it on the ground so you can get under the truck and pin down the location.
Old May 11, 2005 | 09:36 PM
motox214's Avatar
motox214
Well, I know the ball joints were bad, you think they could cause this sound? But, wouldn't they make the same sound if I were to bounce the front end as well as turn the wheel? I had a friend turn the wheel and I couldn't find a distinct area. I do know that it is the front right. He also looked and thought it was coming from the rack and Pinion, but I disagree with that.
Old May 12, 2005 | 08:27 PM
Ken00's Avatar
Ken00
Sometimes you can track down a noise by feeling the vibration, not listening to the sound.
Old May 13, 2005 | 07:02 PM
motox214's Avatar
motox214
Replaced the lower ball joint and fixed the problem! Thanks Ken00
Old May 13, 2005 | 08:28 PM
Ken00's Avatar
Ken00
Glad to hear you got it fixed!!
