another fuel guage problem
Old May 11, 2005 | 08:46 AM
fordsrgrt's Avatar
fordsrgrt
did the test as i read on here . pulling sending wire off and grounding it with key in run position. needle goes to full but not smoothly ,rather a jerking motion then when i pull the ground off nothing .this is on my 74 does this indicate a bad wire or ground .checked and cleaned all connections
Old May 11, 2005 | 02:15 PM
fordsrgrt's Avatar
fordsrgrt
got it ,added another ground and all is fine
