engine removal for gasket change
Good Luck
this is straight from my ford manual out of the "in vehicle repair section". It's a 2000 SD but I think it's the same. Hows that for ya. Good luck.
In vehicle maintenance:
Cylinder Head<O:p></O:p>
Removal<O:p></O:p>
1. Remove the valve covers (6582); refer to «Valve Cover—LH» and «Valve Cover—RH».<O:p></O:p>
2. Remove the intake manifold (9424); refer to «Intake Manifold» in this section.<O:p></O:p>
3. Remove the timing chain (6268); refer to and «Timing Drive Components» in this section.<O:p></O:p>
4. Remove the exhaust manifolds (9430); refer to «Exhaust Manifold—LH» and «Exhaust Manifold—RH» in this section.<O:p></O:p>
5. Lower the vehicle.<O:p></O:p>
6. Slide hose clamp back and disconnect water heater supply tube.<O:p></O:p>
7. Remove the nut and position the transmission oil level indicator tube out of the way.<O:p></O:p>
8. Remove the studs.<O:p></O:p>
9. Slide the water heater tube back and remove.<O:p></O:p>
10. If removing the LH cylinder head, remove the oil level indicator and tube.<O:p></O:p>
11. CAUTION:<O:p></O:p>
The cylinder head bolts must be replaced with new bolts. They are tighten-to-yield designed and cannot be reused.<O:p></O:p>
CAUTION:<O:p></O:p>
Do not use metal scrapers, wire brushes, power abrasive discs or other abrasive means to clean the sealing surfaces. These tools cause scratches and gouges that make leak paths. Use a plastic scraping tool to remove all traces of the head gasket (6051).<O:p></O:p>
Remove the bolts and the cylinder heads (6049).<O:p></O:p>
l Discard the head gasket and clean the cylinder block surface with a plastic scraper and solvent.<O:p></O:p>
l Use Metal Surface Cleaner F4AZ-19A536-RA or equivalent meeting Ford specification WSE-M5B392-A.<O:p></O:p>
Installation<O:p></O:p>
1. Install the (A) head gasket over the (B) dowel pins.<O:p></O:p>
l The RH head gasket is shown; the LH head gasket is similar.<O:p></O:p>
2. Install the (A) cylinder head on the (B) head gasket and loosely install the (C) bolts.<O:p></O:p>
l The RH cylinder head is shown; the LH cylinder head is similar.<O:p></O:p>
3. Note:<O:p></O:p>
Make sure to tighten the bolts in sequence in three steps.<O:p></O:p>
Tighten the LH bolts in the sequence shown.<O:p></O:p>
l Tighten to 37-43 Nm.<O:p></O:p>
l Tighten an additional 85-95 degrees.<O:p></O:p>
4. Note:<O:p></O:p>
Make sure to tighten the bolts in the following three steps.<O:p></O:p>
Tighten the RH bolts in the sequence shown.<O:p></O:p>
5. Install the oil level indicator tube.<O:p></O:p>
6. Slide the water heater tube forward over O-ring.<O:p></O:p>
l Lubricate the O-ring seal with Ford Premium Cooling System Fluid E2FZ-19549-AA (in Oregon, F5FZ-19549-CC, in Canada, CXC-10) or equivalent meeting Ford specification ESE-M97B44-A.<O:p></O:p>
7. Install the studs on the rear of the water heater tube.<O:p></O:p>
8. If removed, install the transmission oil level indicator tube.<O:p></O:p>
9. Connect the heater hose.<O:p></O:p>
10. Raise the vehicle.<O:p></O:p>
11. Install the exhaust manifold; refer to «Exhaust Manifold—LH» and «Exhaust Manifold—RH» in this section.<O:p></O:p>
12. Install the timing chain; refer to «Timing Drive Components» in this section.<O:p></O:p>
13. Install the intake manifold; refer to «Intake Manifold» in this section.<O:p></O:p>
14. Install the valve covers; refer to «Valve Cover—LH» and «Valve Cover—RH» in this section.<O:p</O:p
<O:p</O:p
