Column shift woes
Old May 10, 2005 | 11:34 PM
only1kirk's Avatar
only1kirk
Question Column shift woes
I have a 1974 Ford F-100, 4x2, 302. My column shifter has a mind of it's own. You can shift it into any gear without pulling it towards you. This is a problem. I'm forced to park it in N and use the emer. brake. If I take a corner to fast it shifts into 2. Does anyone know what part I may need to fix this shifter problem, and how to do it? Any info would be greatly appreciated. Thanks.
Old May 10, 2005 | 11:44 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check your cab mounts, a common problem. A broken motor or transmission mount can also cause problems. Sometimes worn parts in the shift linkage can cause problems but yours seem to be movement related so check the mounts.
Old May 11, 2005 | 09:58 AM
beartracks's Avatar
beartracks
There is also a small plate in the steering column called the sector that guides the shifter. It could be worn out.
Old May 16, 2005 | 09:21 AM
only1kirk's Avatar
only1kirk
Yes, I checked my cab mount and it is rusted out. Thanks. That solves one problem. I will have to check the sector next. The shifter still goes left and right into gears without much resistance. Thank you.
