Sponsored by: Auxito
01 screw running ruff
Old May 10, 2005 | 08:56 PM
abmobil's Avatar
abmobil
Hello, My friend has a 01 screw 2wd 5.4 and just a couple of days ago it started running really ruff. Under acceleration its very ruff and there is power loss.
Ignition coils seem to be a common problem on these engines so i was thinking one of the coils went bad and it may be running on 7 cylinders but wouldnt that make the engine light come on?
He went to have it scanned at autozone but without the light on it wont pull any codes. I know some cars will store codes even with the light off. Would this be the case for fords as well?
I was also thinking idle air control valve but not sure.
Its probably going to the dealer tommorow but i was trying to find a solution before he goes that route.
Thanks!
Old May 11, 2005 | 12:33 AM
Racerguy's Avatar
Racerguy
How many miles on the spark plugs? Bad plugs are more common than bad coils...where I am anyway.
Your dealer can do a cylinder power balance test while driving to see which cylinder or cylinders are misfiring. I don't think that anyone else but the dealer has the capability to do that.
A bad IAC can cause a stall or surging idle but won't cause a miss or loss of power.
Old May 11, 2005 | 01:27 PM
abmobil's Avatar
abmobil
Thanks!
I dont think the plugs have ben changed. It has 55k on it.
Old May 11, 2005 | 10:07 PM
jghaviland's Avatar
jghaviland
2000 Supercab 4X4 5.4
I just went through a bout of the same thing, and yes the service engine light does come on. The previous owner replaced the autolight plugs with champion...very bad. I had to use double plat. In addition to requiring new plugs, the rubber plug boots and spring connectors were warn out, cracks and pin holes. These caused the crossfire. I have an excellent mechanic, total cost was $350 p&l. The dealer service quoted me over $600. It is sure great to have a good mechanic you can count on.
