ok im have a 4 inch superlift suspension with 33 tsls at the moment and have a winch bumper that gave me some more clearance on my front with a winch.
with the extra weight it does sit lil in the front but not by much. it has a block not to sure looks like a 2.5 inch or 3 inch block in the rear. so if i buy 6 inch springs and get a 2 inch add aleaf it sould sit pretty even correct?
now after thats all done im wondering would i beable to run my friends
36-14.50 15 truxus sts's on my 15-10 weels with the 6 inch coils and the add aleaf
you will need proper backspacing, extended radius arms, i suggest rear 6" leaf pack vs the blocks that tend to break or spit out which messes up the rear suspension real bad if your wheeling hard. you will also need to remove the suspension brackets and move them to the 6" lift bolt holes as well. might need a new pitman arm also should think about gears to because 3.55's will be a dog running those size tires
