Pcv?
Old May 10, 2005 | 07:47 PM
bulldog3531's Avatar
bulldog3531
Pcv?
How often should you change your PCV valve and how can you tell if is bad or not? 98 SPORT 4.0 SOHC. Thanks
Old May 11, 2005 | 02:55 PM
ledbetter's Avatar
ledbetter
I was looking at a haynes manual the other day, and it mentioned shaking it. If it rattles, it's ok, if not then replace it. I'm sure there are other ways.
Old May 11, 2005 | 06:02 PM
JerrySimm's Avatar
JerrySimm
It's a check valve. If you put your mouth where the hose goes, you should not be able to blow through it, but it should flow the freely if you suck on the connection.
Old May 11, 2005 | 07:32 PM
bulldog3531
Thanks for the replys. I guess mine is good it does as ya'll say.
