Headlight trouble..
Old May 10, 2005 | 04:38 PM
Bo_Duke's Avatar
Bo_Duke
Unhappy Headlight trouble..
OK guys, i have a 2002 F150 Lariat with aftermarket projector headlights. I am running eurolights fusion beams, and after about 5 months, the passenger side just barely glows at night. I changed bulbs, still no headlight. The harness looks a little burned on the end. Can yoiu just replace the plug, or do you have to replace the whole harness? Thanks.
Old May 10, 2005 | 05:41 PM
Franklin2's Avatar
Franklin2
See if someone sells a plug with pigtails that will fit. Otherwise, go to the junkyard and get one. If you solder and shrinkwrap the connection, it will perform as new and look professional.
