Offroad & 4x4
Dana 50 outer shaft
Old May 9, 2005 | 08:14 PM
bonechief's Avatar
bonechief
Dana 50 outer shaft
The outer shaft on my TTB Dana 50 axle is 30 spline..........And the outer shaft on my new Dana 60 is 35 right......So will have to change my hubs inner drive flange to reuse my Dana 50 hubs is this correct.......
Old May 9, 2005 | 09:23 PM
chrono4's Avatar
chrono4
from what it sounds like, you would. you might have better luck in the axle forum. sorry
Old May 9, 2005 | 10:17 PM
fishmanndotcom's Avatar
fishmanndotcom
Dana 50 hubs will swap right over to a Dana 60 axle on older axles, but if you already know your spline counts are different then you already know the answer!
-cutts-
Old May 10, 2005 | 06:19 AM
82F100SWB's Avatar
82F100SWB
I take it your D60 has aftermarket axles, or is out of an 05 S/D? It should be 30 spline if it's a stock ford axle of 78-04 vintage, and the 50 hub should swap right over.
Old May 10, 2005 | 11:57 AM
bonechief's Avatar
bonechief
I was looking at Pirate4x4 and found a spec sheet and i though i had 35 spline outers....On my d60 its out of an 90 f350.......
Old May 10, 2005 | 08:31 PM
mustange70's Avatar
mustange70
Its 30spl outer unless aftermarket. But if they are stock (30spl) then yes the dana 50 hubs will work.
