new/longer I-beams?
Old May 9, 2005 | 06:44 PM
god.boots's Avatar
god.boots
new/longer I-beams?
i got some new coils for my 67 f100 2wd, they lifted the front 4" but my tires are tilted in towards the truck at the front beucase of how long the new coils are. Do i need new I-beams? or do i need to bend them?
Old May 9, 2005 | 08:34 PM
thesprocket26's Avatar
thesprocket26
They will need to be bent or make some drop mounts for the axles.
Old May 9, 2005 | 09:33 PM
god.boots's Avatar
god.boots
which do you think will be easiest? I have a torch but no welder. also if I bend them, do you think I should bend closest to the end? or farthest from it.
Old May 9, 2005 | 10:47 PM
jlasater's Avatar
jlasater
Have a pro do the work. I wouldn't bend any forged suspension parts with a torch unless you REALLY knew what you were doing, and then technically they should be stress relieved when you're done, something the average guy isn't going to be able to do. There are probably complete axles designed for raised trucks, might check them out. Alternately, unless you really want the truck raised, might try sourcing the correct springs for the truck.
The drop mounts move the non-wheel end of the axle down, to level the axle back out and line the wheels up right.
Old May 10, 2005 | 05:15 AM
jowilker's Avatar
jowilker
A better answer would be to get the correct springs, and not bend anything. 4" is an aweful lot of difference. How much difference in the unsprung length?
John
