Side Gapped Plugs ???
Old May 2, 2000 | 01:49 AM
Beeawtch's Avatar
Beeawtch
Will someone please describe to me in detail what side gapped plugs are and how they are better on gas mileage ??????
Old May 2, 2000 | 05:00 AM
slikness's Avatar
slikness
Side gapped plugs are plugs that you cut the electrode back about an 1/8" to expose the anode. This exposes more of the spark to the combustion chamber, which in theory will give you a more powerful spark.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old May 2, 2000 | 03:50 PM
Larry619's Avatar
Larry619
If your theory is correct....wouldn't buying a new Ignition system like MSD do the same trick? I know its expensicve but wouldn't messing with the spark plugs like that cause a detenation or something?
Old May 2, 2000 | 05:01 PM
slikness's Avatar
slikness
I already have an MSD 6A ignition. And that's part of dialing in a complete system. I have headers, an MSD coil and I will probably go with an MSD distributor soon. I also know that I need to fatten up the carb a little with the headers. The old plugs also showed signs of running a little too lean.
Slik
Old May 2, 2000 | 08:18 PM
Beeawtch's Avatar
Beeawtch
Thanks guys.
Old May 2, 2000 | 08:22 PM
familyman's Avatar
familyman
sorry guys, but what is a MSD coil and distributor?
Old May 3, 2000 | 05:16 AM
slikness's Avatar
slikness
MSD is an ignition manufacturer. Most of the NASCAR folks run MSD. MSD produces an ignition that will send multiple sparks to the plug over a longer duration than a standard ignition (at idle). When your engine typically hits 2-3K a standard ignition while only fire your plug once every 2-4 combustion cycles. The MSD doesn't claim to hit every cylcle every time, but it does say that it will hit the combustion cylces more often than a standard ignition set.
Slik
Old May 3, 2000 | 12:22 PM
Pastmaster's Avatar
Pastmaster
Slik, is MSD allready producing the distributor? I most likely will get one of em...
Evan A.K.A. PastMaster
1993 F-150 302/E40d XLT
1989 F-150 302/Aod 4x4 XLT Lariat
Old May 3, 2000 | 12:31 PM
slikness's Avatar
slikness
MSD now has 3 distributors available for the 351W.
1) Their old standard distributor does not have a vacuum advance, only mechanical.
2) They have what they call a drop in distributor that has the vacuum advance and an ignition module built inside the distributor. You just drop it in, hook up 3 wires and off you go. I'm not real positive if the distributor replaces the box on the fender well or not, but it looks like it should.
3) The third distributor is a vacuum advance model that requires you to have an MSD ignition box (6, 6A, 7, etc.).
The third one is the one that I will eventually get and they are all available from MSD today! Summit doesn't list them, but they are in my new 2000 PAW catalog.
Slik
Old May 3, 2000 | 12:36 PM
slikness's Avatar
slikness
