tranny going? or what???
Old May 8, 2005 | 10:09 PM
84FB351's Avatar
84FB351
quick question i hope, when im cruising at 45-55 mph in OD it feels like my motor is cutting out and i assume its my tranny cuz when i hit the Od button it doesnt do it, its kind of like a quick jerking motion like when you run out of gas and it spits and sputters. it only does it between 45-55 and very rarely above 60. what could this be? what can i do to fix it?
also how much MPG does the IAC knock off when it is bad?
Old Aug 4, 2005 | 11:06 AM
StangMang's Avatar
StangMang
This is happening to me also
Old Aug 4, 2005 | 01:21 PM
McLeod's Avatar
McLeod
Sounds like the friction plate in the torque converter (overdrive models) is slipping.
I had to replace torque converter and increase tranny pump pressure to keep it from happening again.
Original cause of problem = OEM tranny pump does not supply sufficient pressure on early E4od trannies.
Old Aug 4, 2005 | 02:01 PM
quicklook2's Avatar
quicklook2
these trans, have a problem called shudder, feels like driving over rough road. if you have this you need to change fluid, filter and drain convertor.
Old Aug 6, 2005 | 09:38 PM
sonic's Avatar
sonic
i thought the same thing..... wasnt the tranny though. Ignition Control Module. Here was my original post. once i replaced the module, the problem NEVER resurfaced
https://www.ford-trucks.com/forums/s...ad.php?t=10208
good luck
