I have a 87 BII with a vibration that starts around 50 km & above.
I have done the following work:
New A arms.
New ball joints
New front wheel bearings
New front rotors
New rear wheel bearings & seals both sides.
New right rear axle.
Have drive shaft rechecked for the 3rd time as this is the 3rd unit in
36,000 KM.Sealed units were not lubed properly.
New rear springs from 2000 Ranger.
Redrilled rear lower shock bracket to 1/2 inch size, too much play before the
bracket hole was 7/16",bolt was 6/16" or 3/8" & shock hole was 1/2 "?.
Had tires rebalanced & rotated. Shocks have 20-25,000 km on them.
HELP
Thank-you 87B2
87B2
