4" downpipe
Old May 8, 2005 | 08:44 PM
7.3whitemonsta's Avatar
7.3whitemonsta
4" downpipe
i have a stock 3.5" exhaust with no cat and no muffler... dumped out before the back tire... can i use a 4" downpipe with it? will it match up or do i need an addapter.. and i ordered a programmer do you think the exhaust is good enough to keep the egts down? thanks
Old May 8, 2005 | 08:47 PM
johnny8's Avatar
johnny8
if you are getting a programer, make sure you have gauges to monitor egt and such... i would go with a 4" exhaust sytem - turbo back... unless you don't tow anything... but either way... gauges are a must...
Old May 8, 2005 | 08:50 PM
7.3whitemonsta
yeah i have gauges.
Old May 8, 2005 | 08:57 PM
johnny8's Avatar
johnny8
well, that will let you watch the egt's while you play with your tunner...! you should be fine, and you'll know if you gotta ease up on the right foot...! i would go with 4" system though... you'll be able to play longer...!
Old May 8, 2005 | 09:06 PM
7.3whitemonsta
will the 4" dp fit??
Old May 9, 2005 | 06:32 AM
RedStroker6's Avatar
RedStroker6
yeah, call Dale at Tymar performance to get your 3''-4'' downpipe for around 140$$ shipped. its a tight fit, but it will work. granted, this is for my OBS truck, but i'm sure the new is the same. then go get some 4''exhaust tubing to take it a little further back put a bend in to get it out from under the truck. should work great.
