Tires fitting without lift kit??
Old May 8, 2005 | 07:20 PM
josh$$$'s Avatar
josh$$$
OK I asked this question a couple of months ago but I never got much of a response. I have 4x4 79 F250 custom. I dont want to lift it. (right now at least) I have finaly got enough money now to buy tires, and i was wondering if 33x12.50x16.5 tires would fit it without rubbing up front. If you know please reply. I think they will but I am not sure. I am 16 and this is my first truck and I love this body stlye. I got it for $600. It was well worth it. it is a 4 speed. black. The body is in good condition. A little rust on the rear wheel arch. And it needs a paint job. only 90,000 oringinal miles. My dad and I both thought that 600 bucks was a steal. First I am going to by tires and wheels. I am looking at some trxus mud tires with outlaw 2 wheels. but i am open to opinions.
please reply
Old May 8, 2005 | 07:58 PM
Thomasm67's Avatar
Thomasm67
You won't have any problems with 33's on that F250 i have a 76 Hiboy which does sit up higher and i run 35's just look in my Gallery.
Old May 8, 2005 | 08:24 PM
Ervin's Avatar
Ervin
Hi, sounds like a nice buy. I just put 33's on my 78 F250 with no lift. I think for next winter I am going to try to get 35's under it. Looks like I still have plenty of room for them. Glad to see another young Ford man. Erv
Old May 10, 2005 | 10:05 AM
Fat&Bald's Avatar
Fat&Bald
My '78 F250 is running 33x12.5x16.5 on it now without any lift, check out my gallery. Will go up to 35's on ARE wheels this fall but will need at least a leveling kit installed up front beforehand.
$600 sounds like a very good deal on your truck.
Old May 10, 2005 | 10:23 AM
77300i6's Avatar
77300i6
Like everyone else stated, they will fit w/o rubbing. Just make sure you have correct backspacing.
BTW: Post some pics of your truck if you can. Would love to see what you "stole" for $600.
Old May 10, 2005 | 12:46 PM
1978fordf250's Avatar
1978fordf250
my buddy fried this on his 1979 ford he tryed to put a set of 33's on with stocl suspention that worked fine and fit fine. Then he tryed to put 35's on it and they fit when the front tires were pointign treight forward but as soon as you turn the front wheels they hit. ( i forget what they hit but i remember him telling me this.) Also what is the metric equivelant to a 33x12.50? Is it a 305x70? Also how tall is a 285x75? I think the 285x75 is jsut as tall as the 305x70 but jsut not as wide. I have a set of 16inch rims and would liek to put a set of 33's on it but they are only 7 icnhes wide will i need new rims?
thanks,
Jimmy
PS I heard a 305x70 needs a 8inch rim to fit. what does the 285x75 need?
thanks guys!
Old May 10, 2005 | 01:39 PM
Bouts21's Avatar
Bouts21
I fit 38" Swampers on the Crew Cab, 3" body lift alone with a 3" fender cut
Old May 10, 2005 | 04:36 PM
Thomasm67's Avatar
Thomasm67
33's on up you need 8 wide or wider same goes for 305 and 285's
Old May 10, 2005 | 05:11 PM
74fordtruck's Avatar
74fordtruck
I have 35"s on a STOCK 76 f-100, so you should have no prob with 33's. The only thing i get into is with a little flex i kiss the bottom of the front fender, but my last truck (same thing only 74) was trimmed up to the body line in very front by bumper, and the only problem I had was once I got the fronts off the ground and landed and they touched in the upper fender.
Why not lift it? Throw some junkyard highboy front springs in there, and some blocks in the back, and you'll have a cheap 4 inches, ready for bigger meats lol I gotta give you some crap, I turn 18 thursday, had a job since i turned 16, and every penny has seemed to find its way into my truck one way or another
Old May 10, 2005 | 07:14 PM
josh$$$'s Avatar
josh$$$
ok i thought the tires would fit thanks for making me sure now
ill try to get pictures but im not sure how to put them on here
Old May 10, 2005 | 07:19 PM
Franken-Truck's Avatar
Franken-Truck
Dito what they said Check my gallery. I have a 78 F-250, with maybe 3"-4" of lift in the front, and 2" blocks in the back (with the stock 3"). It has 38" x 15" Super Swampers on it with out rubin', lock to lock.
Old May 10, 2005 | 08:07 PM
Brad4321's Avatar
Brad4321
I have 38" on a stock highboy, but it is awful close for my liking.
Old May 10, 2005 | 11:35 PM
marcveinotte's Avatar
marcveinotte
Ran 37" goodyear MT's on my stock 78 F250 4x4. Did have an add a leaf up front to level it out( 1" 1 1/2 or so). Just trimmed the front bottom edge of the fenders for a little clearence insurance. I ran a Goodyear for 5 years and we mounted all sort of tires up to rims, regardless of it said in the book it would work or not. In fact I prefered running those 37's ( 12.5 wide) on a 6 inch Ford factory rim ( 16.5). I ran my 325/85R16 Michelins on 16x7's...that worked great too.
Ended up putting a 3" body lift on it as it just looked so goofy with the huge rubber and no lift at all.
Current proeject I will try to mount 41's with a 4" body lift and some trimming of fenders about 4-6 inches each end. These are 12.5R20's ( making up the rims as we speak) and are 20x9 wide. Should be interesting
Old May 15, 2005 | 04:36 AM
kopfenjager's Avatar
kopfenjager
Another thing to think about is most tires are over rated in there size. Some 35's are only 32 and some change. Most 35's are 34.8. Ect. I was told 35's wouldn't fit on my truck so I went with 33's. There seamed to be alot of room so I started measuring. Come to find out they were only 31"s. A true 35 would probley rub but most 35s would fit with no problem. Most tire guys have no idea about true tires sizes and only know what they read in there rfittment guides and what they read on the tires side wall. My advice use a tape measure and measure varieus tires. swampers are often times real close to what they say on the side wall. Just my 2cents. Thanx.
Old May 15, 2005 | 09:50 AM
79 Trailer Special's Avatar
79 Trailer Special
I have a few pics of mine in my gallery, its a 78 with 33x12.50x16.5's no lift and they fit fine also.
cpye2
Oct 8, 2013 07:14 PM
Blang525
18
May 19, 2013 01:53 PM
theramsey3
1997 - 2003 F150
Dec 2, 2012 01:30 AM
X JBM X
Jul 29, 2010 11:36 AM
a_user
Offroad & 4x4
Dec 31, 2006 06:25 PM
