Solenoids
Old May 8, 2005 | 12:07 PM
mike_23us's Avatar
mike_23us
Solenoids
I have a 91' ranger 2wd with a 2.3l and it has a a4ld tranny in it my problem is that my trans wont shift into O/D and since that the 3/4 shift is controlled electronically i would hope you could help i was wondering how i could conduct a Output state test on these solenoids the 3/4 shift solenoid and the at tourque converter lock-up solenoid any at all help would be needed thanks
Old May 8, 2005 | 09:17 PM
Franklin2's Avatar
Franklin2
The first thing I would do is check the codes in the computer. If it sees a serious problem with one of the sensors, it may not let it go in closed loop mode, which would may hold it out of overdrive. It may also see a problem with something like the map sensor or the throttle position sensor, in which it would refuse to let it go into overdrive.
If you want to try to pull the codes yourself, here's how to do it.
http://dalidesign.com/hbook/eectest.html
