Aerostar Ford Aerostar
Bad torque converter??
Old May 8, 2005 | 10:50 AM
biederboat's Avatar
biederboat
Well, looks like the end is near or already here. 93 AWD Aerostar, launched the boat, pulled out and felt a major "lurch". Bascially it drives okay for a short stretch (depending on the speed) and then gives a violent lurch or jolt. Doesn't do it will coasting and is worse at lower speeds or under load. Seems like there was a secondary vibration at higher speeds in OD. Is it possible that it's just the torque converter and is that difficult to replace? I can replace stuff like cylinder heads, transfer cases, axles, etc. but I've never done a torque converter. In any event, it's over for this one, with 182K it's time for a replacement. I'm just wondering if it's worth my while to try and make it a $1,000 used car instead of a $300 used car (if that).
It does have Captain Chairs, KYB shocks, factory ski rack and rear anti-sway bar is someones in the Portland, OR area!
Thanks,
Biederboat
Old May 8, 2005 | 12:40 PM
DaveMac2Vans's Avatar
DaveMac2Vans
I just spent over a grand on my 92, and consider it a much better situation than a $1,000 used car I have no idea about. This has been a great van and will continue to be for many years down the road. I'd much rather have my Aerostar than something else.
Old May 8, 2005 | 02:20 PM
Fordboy49's Avatar
Fordboy49
Hi Folks,
How many miles will a torque converter last?
Thank you,
Fordboy49
Old May 8, 2005 | 07:02 PM
copper_90680's Avatar
copper_90680
168,000 miles and counting for me
Old May 8, 2005 | 09:45 PM
biederboat's Avatar
biederboat
Still looking for an answer, does it sound like a torque converter????
Thanks,
Biederboat
Old May 8, 2005 | 10:03 PM
pauldee0046's Avatar
pauldee0046
No, it does not sound like a torque converter.
Sounds more like something broke and is floating around the valve body.
Pull the pan and do a visual before buying any parts...
Old May 8, 2005 | 10:11 PM
JTHill24's Avatar
JTHill24
Sounds almost like its low on fluid. Try adding a quart and see what happens.
Jay
Old May 9, 2005 | 07:11 PM
biederboat's Avatar
biederboat
Fluid level and quality looked okay. I forgot to mention, it doesn't go into park.
Thanks,
Biederboat
Old May 10, 2005 | 07:48 PM
pauldee0046
A bad torque converter will not keep it from going into park.
Old May 10, 2005 | 07:58 PM
JTHill24's Avatar
JTHill24
I think your shifter cable is out of adjustment. Which means it only halfway into gear.
Old May 10, 2005 | 08:02 PM
biederboat's Avatar
biederboat
Okay, that last one makes some sense. Hopefully the manual will tell me how to adjust it. I suppose it makes logical sense that it has stretched/loosened rather than tightened?
Thanks,
Biederboat
