Hot intake manifold
Old May 12, 2000 | 11:09 AM
Guy's Avatar
Guy
Hot intake manifold
I did some driving around town this morning and shortly after performed a compression test of the engine. When I rested my hand on the intake manifold it was almost hot enough to burn. I know there is the EGR valve but isn't it supposed to get cooled by the coolant flowing through where the egr gases come in? Is it normal for it to get that hot?
'92 F150 XL 4x4, 5.0L AOD, Headers, K&N Air Filter, 3.55 Gears, 31x10.5x15 Tires.
Old May 12, 2000 | 03:10 PM
dougnickels's Avatar
dougnickels
Hot intake manifold
The valve does get quite hot-it's attached to the engine, and hot exhaust gases pass through it. It's also right above the manifold.
Old May 12, 2000 | 04:57 PM
Guy's Avatar
Guy
Hot intake manifold
Thanks dougnickels but my main concern is if it being that hot is normal? That would sure affect performance. I don't have any trouble codes and the power drops significantly after the engine is warmed up.
Old May 12, 2000 | 05:40 PM
SHANE_2's Avatar
SHANE_2
Hot intake manifold
Yes it is normal to get hot. I would look at the cats, make sure you have sufficient flow out the tailpipes. That is a sign of the cat plugging up. What was your compression like? How about the obvious stuff like plugs, fuel filter, air filter and have you had the injectors cleaned?
Old May 13, 2000 | 08:50 AM
slikness's Avatar
slikness
Hot intake manifold
cjben
Apr 11, 2023 01:01 PM
artfd
1997 - 2003 F150
50
Nov 29, 2017 06:37 PM
Tasteslikeink
1997 - 2003 F150
24
Mar 25, 2014 06:08 PM
bluecobra
1997 - 2003 F150
Aug 13, 2012 08:15 PM
murphydo
Jun 24, 2001 05:36 PM
