Sponsored by: Real Truck
which is better?
Old May 7, 2005 | 09:08 PM
PrarieOyster's Avatar
PrarieOyster
which is better?
For lifting +/- 4", which would be better... a track bar relocating bracket or an adjustible track bar?
Old May 7, 2005 | 09:58 PM
02superstroker's Avatar
02superstroker
Well if you are going to use a drop pitman arm you need to get a lowering bracket to retain the matching angles. An adjustable bar would still be handy in getting it just the right length though.
If you arn't doing a drop pitman arm, then I would just go with an adjustable trac bar that way you can keep the proper angles, but keep the axle centered correctyl with the proper length trac bar
good luck.
Old May 8, 2005 | 09:44 AM
PrarieOyster
gotcha, if i am going to get a drop pitman arm, get both the drop bracket and adjustible track bar. I didn't think about the angle concept with the drop bracket.
