Loud Creak when turning
Old May 7, 2005 | 03:56 PM
chadwj's Avatar
chadwj
I have a 2000 Mountaineer. It developed a creak when going over bumps but when the temp outside warmed up itwent away for a few months only to come back recently.
Now we hear the very loud creak when turning the steering wheel as well. The sound comes from the front passenger wheel area.
If anyone can give me an idea as to what the sound is I would appreciate it. Then I can look into how I get it fixed (do it myself or take it in and spend a small fortune).
I initially thought suspension until it started making the sound when turning the steering wheel.
Thanks for your help
Old May 7, 2005 | 05:32 PM
oshoguno's Avatar
oshoguno
Sounds like balljoints and tie rods. Does the sound come from one side or the middle? Do you feel anything in the steering wheel?
Old May 7, 2005 | 08:40 PM
chadwj's Avatar
chadwj
The sound is only from the front passenger wheel area. Thee steering feels normal just loud.
Old May 7, 2005 | 10:29 PM
waro's Avatar
waro
I would recomend you to check outer and inner tie rods. Inner rods tend to produce the noise yr are describing, Same thing happened to me. Took truck to 3 differents mechanics during a 3 years period. Finally both sides inner rods were replaced and loud creek npise dissapeared. Excuse my english it is a bit rusted I am in Venezuela South America.. Good luck
Old May 8, 2005 | 02:06 PM
drcoffee's Avatar
drcoffee
there's too many moving parts down there to start speculating. Turn on the engine and lay under the truck by the tie rod / ball joint area and have someone turn the steering wheel to reproduce the sound. That was the only way I could isolate the ball joints on my '96 AWD X. Just be careful and don't stick your fingers in the moving parts as tempting as it may be.
I've got odds on the ball joints. Been there done that. And it is a DIY if you are comfortable turning a wrench. I'd rate it a #3 out of #5 difficulty level project.
