302 EFI swap
Old May 7, 2005 | 09:34 AM
bpete's Avatar
bpete
Question 302 EFI swap
I am planning on putting a 1983 302 out of a cougar into my '80 Bronco to obtain fuel injection. This is a throttle body/central fuel injection. I am getting complete donor vehicle. What are the draw backs to this type of system?
Old May 10, 2005 | 11:36 AM
Kemicalburns's Avatar
Kemicalburns
that efi is not that great. you would be better off sticking with carb or go to a true efi like from a stang. also that cougar motor wont be a good choice because its cam is suited for a light weight rig an its power band is way high in the rpms. you will at least need to swap to a cam more suited for your 4x4. then just swap over everything else off of your 80 motor and your set. if you want efi check out www.fordfuelinjection.com
late
