Dana 70 U
Old May 6, 2005 | 11:31 PM
Broke_Okie's Avatar
Broke_Okie
Question Dana 70 U
I own a 71' F100 4X4 . I recently found a Dana 70 U in a 74' F350. It is a dual rear wheel rear end. Can I use this in my truck as a single rear wheel dif? If so what will it entail to do so?
Old May 7, 2005 | 06:19 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 9, 2005 | 12:03 AM
Broke_Okie's Avatar
Broke_Okie
Has anyone done this before??
Old May 9, 2005 | 12:38 PM
51dueller's Avatar
51dueller
You can run single wheels on a dually axle with no problems. To change it would require removing the back plate flange and moving it to the single wheel drum width. I'd keep the stock drums as they are bigger than the single drums. 12x3" to 12x2.5". I'm running single wheels on a '74 F-350 axle in my '51 truck. Are you sure it's a 70 U, mine is a 70 B.
