E4OD torque converter lock-up?
Old May 18, 2000 | 07:43 AM
slikness's Avatar
slikness
Old May 19, 2000 | 06:54 PM
rockcrawl's Avatar
rockcrawl
I was wondering if anyone knows how I can prevent the torque converter lock-up in 3rd gear. My truck is a 92 Flareside 4x4 with the 351 and E4OD with a B&M shift kit and 4.56 gears. It works wonderfully except that the converter locks up almost instantly after it shifts into 3rd, which lowers the RPM and robs me of power. Is there any way to disable the lock-up feature, like pulling the plug on a GM700R4?
Old May 19, 2000 | 09:50 PM
Torky's Avatar
Torky
The 94 book shows pin 4 of the 12 pin connector at the E4OD trans as being the Torque Converter Clutch Solenoid pin. The wire color code is Purple with Yellow stripe. Could try cutting that wire, and see what happens. Suggest cutting it away from the connector, so you could connect it back up again if need be.
Old Feb 15, 2011 | 06:52 PM
92f2504x46.9's Avatar
92f2504x46.9
just lightly touch brake pedal (just enough to make lights come on)
Old Feb 15, 2011 | 08:54 PM
smashclash's Avatar
smashclash
see that silkness, just under 11 years but you got your answer!!!! good luck buddy!!
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Aug 22, 2012 11:39 PM
