Sponsored by: Real Truck
Bent AC Condensing Coils
Old May 6, 2005 | 06:28 PM
peakgolf's Avatar
peakgolf
I noticed the AC Condensing Coil inside the grill of my 2004 SD are flattening out, perhaps from bugs hitting coils? Is this normal? Is there a screen available to put in front of the Coil to prevent this?
Thanks in advance,
Peakgolf
Old May 6, 2005 | 06:58 PM
Rongold's Avatar
Rongold
Ac Condenser Fins
You would need an awfully big bug to bend the fins. Most condensers have flat spots in the fins--usually from careless handling when the vehicle was assembled , or from a front collision. You can get a condenser "comb" from most auto parts houses. You can usually comb out the flat spots if you can get at them. Taking out the grille on SD's is not too hard, and that would give you more access to do the job. Unless more than 25% of your condenser is flattened, I would not worry about it.
RON
Old May 6, 2005 | 07:24 PM
peakgolf's Avatar
peakgolf
Ron,
Thanks for the info,
Peakgolf
Old May 7, 2005 | 12:52 AM
moneypitt's Avatar
moneypitt
Its usualy rocks and big things like that that bends the fins get a fin colmb and strait them out
hombre292
Oct 18, 2014 04:34 PM
Steve Aerostar
Aerostar
Sep 9, 2014 10:30 PM
ruhlronnan
Arizona Chapter
Jul 30, 2013 03:23 AM
dbag
Aug 15, 2012 08:36 PM
