Radio Removal
Old May 22, 2000 | 04:05 AM
pffourn's Avatar
pffourn
Radio Removal
I have a '96 F-250 with the factory am/fm radio still installed. I am upgrading to an indash cd player and wondered if there was a way to get the old rdio out without taking the dash all apart.
Old May 22, 2000 | 08:34 PM
dcoker18's Avatar
dcoker18
Radio Removal
There should be holes in the corners of the factory radio you can take a wire coat hanger and place in each hole it should come right out if not make sure the coat hanger has pushed the clamps open if you need to you can open glovebox press side of it over to drop the box down reach inside and push the radio a little
Old May 22, 2000 | 08:43 PM
jamden's Avatar
jamden
Radio Removal
If your 96 has the late model radio, like the one in my 92, you'll require special tools to remove them. I've not done it but once you have the tools the removal looks like a snap. Just insert the tools into the holes in the faceplate. Press them in to release the radio retaining clips and pull out the radio. You would probably have to go to a dealer or a radio shop to get the tools.
1992 F150 Supercab SB 4x4 302 AOD 3.55
Old May 23, 2000 | 08:53 AM
cgl's Avatar
cgl
Radio Removal
Try Wal-Mart, for about $3 you can get the Ford Factory Radio Removal Tool. You get two metal "U"'s, one for each side. Push them in till they click, then push the clips to the outside and pull. The radio will slide right out.
Old May 23, 2000 | 01:26 PM
pffourn's Avatar
pffourn
Radio Removal
THANKS FOR THE INFO EVERYONE. GOT THE RADIO OUT AND THE NEW CD PLAYER IN. SOUNDS GREAT!
Old May 23, 2000 | 02:33 PM
cbremer's Avatar
cbremer
Radio Removal
(huh, now he's yellin'... new CD stereo must be affecting his hearing) </joke>
Old May 23, 2000 | 06:12 PM
85351ho's Avatar
85351ho
Radio Removal
Old Apr 21, 2007 | 01:29 PM
jimgcan's Avatar
jimgcan
Talking Thanks for the tip!
I bought the radio removal tool (after trying unsuccessfully to use coat hanger wires) but it still would not work. I'm thinking, "Great, gotta take apart the dash to get this thing out."
But after reading this post, I realized I had to push the removal tools towards the outside to release the radio. It still required quite a bit of force, but the radio finally popped out with no damage.
Thanks for the tip.
Satch
1997 - 2003 F150
Jan 29, 2016 07:35 PM
johnsonjf
Dec 18, 2014 09:11 AM
JAMillsUSMC
Dec 1, 2014 08:30 PM
Zachthemoo2
Oct 7, 2014 10:30 AM
timmyjimmy5150
Dec 14, 2005 09:29 AM
