Vacuum lines
Old May 5, 2005 | 03:10 PM
Rack14's Avatar
Rack14
Question HELP.....Vacuum lines!?
Hello everyone
I finally went out and got my first toy and it happens to be a 79 4x4 with a 460 in it, i got it for 200 dollars so you can imagine the problems. What i am getting right now is when i start it up it idles fine, once warm i can throw in reverse and thats fine also but when in drive it will go a bit and cut out, sometimes i can give it alittle gas and it will gradually cut off and if i punch it...automatic shut off, i can hear the the air and i am pretty sure it is a vacuum leak but i haven't had much time to get into it and look around, just off these indications does anyone have a good guess of where i can start......it's a pretty stupid question but like i said....i am new at this and determined.....
Old May 5, 2005 | 08:36 PM
ivanribic's Avatar
ivanribic
Hello and welcome!
First thing I was do is change the fuel filter. This is $5 and a lot of times can cause you major headaches when junk gets in there. If the truck was sitting quite a while the carb may need to be rebuilt too, but start with the filter.
In terms of vacuum there's a fair amount of emissions junk on those trucks so you'd really need to trace all the lines to see if there's a leak. If you can hear the leak then it's most likely going to be a hose that's loose so it should be fairly easy to spot. Check the vacuum tree behind the carb and see what you can find.
Old May 9, 2005 | 05:16 PM
Rack14's Avatar
Rack14
Thanks for the reply, i got under the hood and messed around alittle but i didn't get much time to get indepth. i did notice a hose coming off the back of the carb was unconnected so that is where i am gonna start. as for the fuel filter, that is a constant problem, i picked up a new gas tank fo the truck, the old one is pretty rusty. everytime i mess with it i have to bang out the filter, i see no reason to change it until the gas tank is changed out. i will let you know how it goes when i get back into it.
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
7point3turbo
17
Sep 6, 2014 06:57 AM
fnc
Nov 2, 2010 12:40 PM
Jodell
Mar 5, 2009 08:23 PM
niteowl
Jul 16, 2004 11:54 AM
