Anyone know where I can get a digital EGT gauge for my '05 F250 Harley Davidson 6.0 SD? I would like to mount it in the open space where the upfitter switches would have been. I've looked at the pillar mount systems but there is a large handle located on the top of the pillar now. I don't want to lose the handle and it will look too crowded if I leave it on with the pillar mount gauges. Or any suggestions to what I can do?
You could look at a single pod mount that goes on top of the steering column. It would be a very clean install, be out of the way, easy to see, and would retain your handle. Check eguages.com or dieselperformanceparts.com/ford.html for various mounts.
I got the X monitor in my '05 and it mounts right under the grab handle, thus, no need to remove it. It's been great so far and I really like the looks. Check out jegs.com!
