speedo tooth count?
Old May 5, 2005 | 10:41 AM
bigbadford78's Avatar
bigbadford78
speedo tooth count?
what gear count do i need for my speedo ring? i have a 78' ford with a c6/203 3.90 gears and 35inch tires, the tranny shop told me i needed a teeth count so i could order a new one, i am guessing my ring is broken or stripped, i can undo the speedo cable and run it with a drill just fine, i really dont want to have it down for a couple days nor do i want to tear into it twice.....please help!
Old May 5, 2005 | 04:36 PM
stuart1's Avatar
stuart1
The drive gear is cut into the ouput shaft and is not replaceable.
It could be 6-7-8 or 9 tooth.
The teeth on the driven gear can be counted easily. Just remove the cable.
You can look inside the speedo hole and count the teeth as you turn the output shaft.
Old May 5, 2005 | 07:51 PM
bigbadford78
well then what is the deal? why is my speedo cable not getting spun when installed into the t-case.....wouldnt there be a plastic ring that slips onto the output shaft just like a chevy?
Old May 5, 2005 | 08:59 PM
stuart1's Avatar
stuart1
Ah. Ok I didn't read the 203. Sorry.
But you can still count the teeth.
