351 in a 46
Old May 5, 2005 | 12:55 AM
magicbus's Avatar
magicbus
351 in a 46
Does anyone know if a 351w will fit in both directions under the hood of a 46 truck?
Old May 5, 2005 | 07:22 PM
46yblock's Avatar
46yblock
If you have dimensions, I can compare them to a Y-block. I would think it should fit in width. Length may require relief in the firewall. My Y only has about 3/16 to 1/4 inch clearance between the firewall and right rocker cover.
Old May 6, 2005 | 06:21 AM
46achers's Avatar
46achers
The 35iW is not much different size wise than a 302 so there should be no real problems. You will probably need to go with a rear sump oil pan to drop it down behind the front crossmember.
