tranny problems
help us help you
late
You can go to autozone.com and click on the link to Vehicle Repair Guides to find the adjustment procedure. Adjust the TV cable first. If that doesn't fix the problem then you can start looking to problems with the governor or valve body
Thanks for the site, now how do I go about adjusting it?
PS. maybe I should change my major to automotive something or other, rather then civil engineering. LOL
AOD Transmission With Fuel Injection
ADJUSTMENT WITH ENGINE OFF
- Set the parking brake and put the selector lever in Neutral.
- Remove the protective cover from the cable.
- Make sure that the throttle lever is at the idle stop. If it isn't, check for binding or interference. NEVER ATTEMPT TO ADJUST THE IDLE STOP!
- Make sure that the cable is free of sharp bends or is not rubbing on anything throughout its entire length.
- Lubricate the TV lever ball stud with chassis lube.
- Unlock the locking tab at the throttle body by prying with a small screwdriver.
- Install a spring on the TV control lever, to hold it in the rearmost travel position. The spring must exert at least 10 lbs. of force on the lever.
- Rotate the transmission outer TV lever 10-30° and slowly allow it to return.
- Push down on the locking tab until flush.
- Remove the retaining spring from the lever.
I don't see a ball stud, also I don't understand why you install a spring. I just put the truck in N, and adjusted the tv cable to the very last slot before the engine started to rev higher. I did twist the cable like it said, I don't know why I guess to get some kinks out. I made sure the cable wasn't in contact with anything or had any sharp bends. It still bogs down but not as much. I hope its nothing seriouse. I called a guy at a tranny shop and he said that it sounded like wha tyou have been saying. so i am guessing you all are correct but I don't understand why its still doing it a bit.
