1978 - 1996 Big Bronco
86 aod shifting
Old May 4, 2005 | 04:06 PM
smr085's Avatar
smr085
86 aod shifting
i have an 86 ford bronco with an aod trans it shifts from 1st to 2nd but wont go into 3rd or overdrive does anyone have any suggestions
Old May 4, 2005 | 05:01 PM
gjordan456's Avatar
gjordan456
did you notice anything different prior to this happening? the reason I ask is when my AOD went it was slipping and then finally stoped going into 3rd and OD, I had it rebuilt and the tranny guy told me 3rd gear was gone...
Old May 5, 2005 | 06:40 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
smr085 ...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 5, 2005 | 09:46 AM
Kemicalburns's Avatar
Kemicalburns
have you changed the fluid and filter in the tranny recently? might be due for a service . start with the cheap things first. if it is infact toast then talk to some local tranny shops , might as well get it built to handle any future mods. here is a sweet tranny if you can spring for it. has a very strong gear set and lower first second gears which help for 4x4in and towing. and can handle some 400 hp to which is always good
http://ckperformance.com/ford_aod_2.html
AOD-HDSR/TPWR- TOWING PACKAGE (REVISED VALVE BODY CALIBRATION WITH MOTORSPORT WIDE RATIO GEAR SET) $1399.00
Old May 6, 2005 | 08:15 AM
Bodyman Chuck's Avatar
Bodyman Chuck
try reseting the tv cable
Old May 6, 2005 | 09:34 AM
Kemicalburns
gotta be careful reseting the tv cable. use your haynes manual when attempting this step cause its real easy to seriously toast the tranny if it isnt already.
