Anyone know if those rubber sweeps that are at the base of the windows (outside) that wipe off the dew in the morning when you roll down the window, are still available. The Phoenix sun has destroyed mine and I'd like to replace them when I paint the truck (89 Bronco)
You may as well also do the rear window while your at it........I am totally **** about keeping as much moisture out of my tailgate as I can so I did all the rubber at the back.....glass to cap, both top corners of the t-gate, both inner and outer sweeps, and t-gate to bed seal. I also did the front windows.
Yeah, the back window sweep is just as bad as the side windows. I didn't see that listed though on the Broncograveyard site Am I missing it or is it available elsewhere?
