turn signal
Old May 3, 2005 | 08:26 PM
1979ford's Avatar
1979ford
turn signal
I have a '79 F150. My left turn signal works fine, but only my right rear turn signal works. It doesn't work in the cab or with the hazard switch. Does anyone have the schmatic for the turn signal circuit?
Old May 3, 2005 | 09:54 PM
Franklin2's Avatar
Franklin2
Here's a diagram. I would start at the steering column, since your directional light in the dash doesn't work. Check the white/blue wire for an on-off 12 volt signal. If you are not getting it at the steering column, I would suspect the turnsignal switch or the plug that plugs into it.
http://www.autozone.com/images/cds/g...3d800ce987.gif
Old May 4, 2005 | 10:45 AM
73Custom's Avatar
73Custom
There is a good tech article about testing and diagnosing turn signal problems. Link at top of page under Articles then List Articles.
Marty
