rust on dip stick
Old May 3, 2005 | 04:26 PM
78_ford_F150's Avatar
78_ford_F150
rust on dip stick
ok in the morning i check the oil in my 78 ford 400 and there is rust on the dip stick what made this happen and how do i fix it.
Old May 3, 2005 | 07:12 PM
cowhide1's Avatar
cowhide1
I had the same problem with my 81 f150. It is caused by condensation in the crankcase, probably caused by blow by.
I solved the problem by going to the junk yard and getting a van dipstick and cutting it to the right length. this gets rid of the rust prone top section of the stock dipstick. Just mark the right levels with a file, the next time you change oil.
Old May 3, 2005 | 10:55 PM
Torque1st's Avatar
Torque1st
Posting Legend
Short trip driving that does not heat up the engine and an inoperative PCV system can cause heavy moisture accumulation in the crankcase. Just because the PCV valve rattles does not mean it is good. Replace it annually or every 12,000 miles.
Old May 4, 2005 | 12:50 PM
78_ford_F150
can this cause any damage the the motor
Old May 4, 2005 | 12:54 PM
Torque1st's Avatar
Torque1st
Posting Legend
Yes it can so get it fixed.
Old May 9, 2005 | 12:46 PM
78_ford_F150
i think it already did i was coming home from the city and could hear a tick like the hedders where leaking but about 10 miles down the road it started to nock it sounded like a jakhammer after about 20 miles of that it stoped making that noise now theres just a little tick and i have no power at all it starts good has oil presser i dont know what to do i want to get some info before i take the motor out
thanx
mkrog
Apr 12, 2012 10:56 AM
iron1951
May 21, 2010 07:42 PM
Rickman57
Aerostar
May 7, 2010 05:50 PM
CaptainIPSC
Aug 13, 2009 10:35 PM
ford78f250
Jun 29, 2001 07:07 AM
