Smog Pump / A/C Deletion...?
Old May 3, 2005 | 04:24 PM
90F1505.0L's Avatar
90F1505.0L
Question Smog Pump / A/C Deletion...?
My question is can I bypass my smog pump and a/c compressor by putting on a shorter belt. Where I live there is no emissions testing. The truck is strictly for off-road use only.....
Old May 3, 2005 | 04:40 PM
andym's Avatar
andym
Unless the pump is seized, you will gain absolutely nothing by doing this. The air pump takes virtually no power at all to run. You can guesstimate a belt length using a piece of string.
Old May 3, 2005 | 04:55 PM
Cruiseomatic's Avatar
Cruiseomatic
What is the air pump and what does it do?
Old May 3, 2005 | 05:19 PM
fordtrck302's Avatar
fordtrck302
the air pump basically run clean air into your exhuast between the two converters it just helps with the emissions
Old May 6, 2005 | 08:11 PM
skyfox10's Avatar
skyfox10
if you are going to remove the air pump you will need to plug where it enters the exhaust. also, i've heard that this can cause a problem with that cats. i removed my cats last fall and decided to get rid of the pump since it wasn't doing anything at all. i had pulled of all of the extra a few months ago but just finally actually removed the pump today. i have A/C on my truck still so i don't know what belt size you need for that. but after about 4 trips to carquest my 95 f150 4x4 351 with everthing minus the air pump is using a 2440mm length belt. i hope this is some help.
