Intake finish
Old May 3, 2005 | 03:22 PM
wickymustang's Avatar
wickymustang
Intake finish
I have a 95 F150 with the 4.9L 300. The intake manifold paint or whatever it is has cracked at all the edges of the lettering on the top. How do I go about removing this and then should I paint with high temp paint or just normal paint?
Old May 5, 2005 | 11:42 AM
wickymustang
Anybody at all?
Old May 6, 2005 | 12:45 PM
wickymustang
Somebody has to have some experience with this?
Old May 6, 2005 | 01:20 PM
Carlene's Avatar
Carlene
Admom
Since no one else has jumped in, I asked hubby for his advice.
The best and easiest way to remove the old paint would be to work with the manifold off. Then you can sandblast it clean (best), hand sand or try some kind of paint removers.
As for the paint, you do need to use a heat tempered paint.
Old May 7, 2005 | 06:25 PM
77460ford's Avatar
77460ford
Or you could....
have it ceramic coated if you already have it off. Looks great when done.
John.
Old May 8, 2005 | 09:36 PM
wickymustang
How much roughly does ceramic coating cost?
Old May 9, 2005 | 05:04 AM
77460ford's Avatar
77460ford
Re: ceramic coating cost
I had a Performer RPM manifold done, the aluminum was rough cast so that had to be polished first then coated. The shop charged $200 (Cdn.) for the whole job. Not as cheap as paint but it looks unique and keeps the charge as cool as an air gap manifold (according to magazine articles). Hope that helps.
John.
Old May 9, 2005 | 08:53 AM
wickymustang
Ok, I have been out of the money exchange market for a while. Somebody from north of the border wanna translate your money to american?
Old May 9, 2005 | 03:41 PM
77460ford's Avatar
77460ford
$1.26 Canadian gets you one American dollar.
Old May 9, 2005 | 05:52 PM
7fords's Avatar
7fords
powder coating works well also. you can do it yourself easy enough harbor freight sells a nice little setup that is very inexpensive. to bake the finish on all you need is an old oven or earplugs for when your other half catches you using hers
Old May 9, 2005 | 09:17 PM
Carlene's Avatar
Carlene
Admom
You might want to change that to AND earplugs.
