Headlight problem
Old May 3, 2005 | 02:31 PM
JICASE's Avatar
JICASE
Headlight problem
I have a 95 powerstroke with a lot of miles. The other night coming home the headlights started pulsating. They were flashing in a sequence of about the same speed as the hazard lights do. It was almost like a relay was warming up and causing the problem. My question, Is there a relay anywhere in the light system that would cause this? Is the dimmer switch the problem. It seems like it will do it quicker with the brights on than with the dims. About 10 minutes with the brights about 15 with the dims. If you shut the lights off for a bit will take less time for them to blink. What the heck is the problem. It definitly in the headlights only, cause the clearance and parking lights do not blink. Thanks for the help.
