Anti-theft switch
Old Jun 16, 2000 | 11:45 AM
jorge's Avatar
jorge
Anti-theft switch
Hi,I have a 2000 F-150 XLT 4.3 6 cyl. 5 speed. I want to install a "momentary" switch on the wires that go to the safety switch in the clutch, I see 4 wires there, witch 2 are the ones for the starter?, 'cause I understand the other 2 are for the cruise control. Thanks for your help.Ps: Also can I interupt the inertia switch wires and install a kill switch there?.
Old Jun 16, 2000 | 06:03 PM
kioolt's Avatar
kioolt
Anti-theft switch
If you try the forum for your year truck you might get a quicker answer.
Old Jun 16, 2000 | 06:49 PM
PAUL_2's Avatar
PAUL_2
Anti-theft switch
Jorge ,
Its best to consult a wiring diagram before you go cutting and splicing . Since the Inertia Switch is the last stop on the electrical train to the fuel pump and its only 2 wires , that may be the better location to install your kill switch . Just remember that if you short anything out warranty is not going to cover the damage . Make sure you use proper connectors and a quality switch otherwise you may end up keeping yourself from starting the engine .
Paul
Old Jun 17, 2000 | 02:28 PM
shotgun's Avatar
shotgun
Anti-theft switch
I installed one on my 96. My wire is red with a light blue stripe. Yours may be different. You can get a Haynes manual if they are available for about $13.00 to be sure. The "DOT" intermitten switch from Radio Shack cost me $1.59 and is easy to hide. I left two bare spots on the wire. I carry a 6" wire with aligator clips in the glove box. If I have to leave it with a shop or someone else? I just jump the wire to bypass the switch.
Old Jun 17, 2000 | 07:04 PM
cbwarrior's Avatar
cbwarrior
Anti-theft switch
