Rebuild Or Replace 302
I bought this in early feb and it ran really well with a small exhaust leak. Well the check engine light came on and so I checked the codes several times and it said coolant temp sensor and the parts store said it doesn't have one so my Husband swore I did it wrong and the next week before he was able to check it overheated badly. The back pressure caused the water resevoir to back and was at a rolling boil. The temp gauge read on the R of NORMAL. So waited for it to cool off and drove it home about 20 miles and it died in the drive way. I found out after it overheated and the mechanic thinking I would be lucky and it would only be a waterpump. So it sat a while until my Husband had time to change the waterpump which was rusted on and 4 of the 7 bolts broke. A Omen right there
. And that was wrong and so we went on to the head gasket and guess what not that either, it turns out that it has a damaged piston. It looks as if a chunk fell off of it. Any way I was told we can rebuild that one or buy a crate engine 302 small block from Schucks for $722 and resurface my heads and so on. What would you think?I at loss I really can't afford anything. We will have to sell our 3rd rig a 91 Bronco II which is a bummer cuz we really like it. I just like my F-150 better.
Thanks,
Kallie
Looking back on it now, I should have gone with a crate motor and have peace of mind knowing that it came with a warranty that would be backed up.
Crate engines are great except when you get one that is bad. It is even worse when you get two in a row that are bad. I had to swap two bad 4.9's in my old F-150 due to one burning two quarts of oil in 1000 miles and the other burning anti-freeze. The warranty paid for the new motors and they gave me $420 for each swap but it was a major PITA.
Not trying to scare you but IMA, a good local motor rebuilder beats an assembly line crate motor. A reputable local guy should give you a good warranty.
On the other hand I personally didnt have the time to rebuild it myself and dropped a used 302 into my truck... it purrs beautifully so far... (Only had it in for about a week now) and it came with a 30 day warranty for 500 $ Plus I didnt have to give them my core! SO now I got a 302 in my garage to rebuild for later.
I had the same problem like you did with my old 302. so i went down to the local wrecking yard and picked up a used 351w that had 80kmiles and 170 compression on all 8clynders for $800 bucks. this motor was complete from upper intake to oil pan and swaped right in to my full size bronco. only had to change the flexplate and Exhaust Y pipe. ive had this motor in my bronco now for 2yrs and it runns so much better and gets the same mpg as the 302 did but 40lbs torque more. i would for sure go the junkyard route first for cheapest and easiest . otherwise check out on the web some other engine builders that offer better motors then your shmucks. only chain motor i would ever run would be a napa motor because most have inhouse machine shops
