Engine Codes
the transmission shop found two codes relating to the O2 sensor, I believe. If the sensor needs to be replaced, can I do this myself easily? How much for a new sensor? What do I need to know to get a new sensor for my Truck? It is a 1994 F150
I6 AOD Short Box.
Thanks in advance
Cookie
You can replace the O2 sensor if it needs it . Unplug the O2 Sensor Connector , I have an O2 sensor socket which works best , but some have used other means , pipe wrenches etc to remove them . The cost depends on where you purchase it . Im pretty sure the Ford one is around $100 . Aftermarket ones Im sure are cheaper .
Paul
